× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
unable to install firmware hotfix
jmclh
D6220 Firmware Version 1.0.0.56 - Hot Fix
I am trying to install this security hotfix but the downloaded zip file, when opened produces a file name ending in .chk. When I try to upload this in the router's gui it gives an error message saying the fiename is invalid and should end with *.img. Can anyone help please?
Model: D6200|Dual Band 11ac ADSL Modem Router
Message 1 of 2
Accepted Solutions
antinode
Guru
Re: unable to install firmware hotfix
> I am trying to install this security hotfix [...]
   Onto _what_, exactly?  Look for "Model" on the product label.
   "D6200" and "D6220" are spelled differently for a reason.  The D6200
seems to use a ".img" file; the D6220, a ".chk" file.
> [...] When I try to upload this in the router's gui it gives an error
> message saying the fiename is invalid and should end with *.img. [...]
   Loading a firmware image for the right device might help some.
Message 2 of 2
All Replies
antinode
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1329 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
