Orbi WiFi 7 RBE973
wnr2000v5
widmart
Follower
wnr2000v5
I was told by my internet provider that i have horrible speeds due to my router being in "bridge" mode and to take it off... Anyone know how to go about this
Message 1 of 4
Guru
Re: wnr2000v5
What speeds do you get?
The wnr2000 is a base model n300 device and isn't going to have very fast speeds.
Its ethernet is only 10/100mbps and its n300 wireless is maybe going to give you 40-50mbps max in a decent environment (low interference)
Message 2 of 4
Re: wnr2000v5
Looks like more evidence that tech support at many ISPs is, to put it mildly, rubbish.
For a start, your router isn't designed to support "bridge mode", whatever your ISP thinks this is. That's a label that gets used in different ways. depending what we are talking about.
@plemans has already started the ball rolling,
Your wnr2000v5 is a router which means that it probably sites behind a router. What is that?
What speeds do you pay for? As @plemans says, your router is old (first released in 2008) and slow. If you are paying for speeds faster than 100 Mbps you are throwing money away.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Message 3 of 4
wcalifas
Prodigy
Re: wnr2000v5
That router is pretty old, I suggest you get something newer to get higher speeds. You can use that router as an access point if you need to expand your signal somewhere where it's weak.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1169 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi 770 Series
