Orbi WiFi 7 RBE973
Reply
ACL rules
hacesoft
Tutor
ACL rules
Good evening,
i have 4 VLANs for the switches. I played with ACL rules and I was not successful. I always blocked my entire switch perfectly with the first rule.
Information I draw from :
- url: https://drive.google.com/file/d/0B4PuVEYxkQ5ocDhobmZrS1JmNmc/view
- https://drive.google.com/file/d/157I76Cj18C2t3QgM5fRSPNTZuxVvec11/view
I only want to define Internet access on VLAN30. from VLAN11 disable access to the switch and some specific addresses from VLAN20. VLAN20 Unblocked access to any VLAN. Internet is on VLAN10.
The IP address of VLAN10 is: 192.168.10.1
The IP address of VLAN11 is: 192.168.11.1
The IP address of VLAN20 is: 192.168.20.1
The IP address of VLAN30 is 192.168.30.1
Can you direct me how to write ACL rules ... somehow I get lost ...
Thank you for any information ...
Model: GS724Tv4|ProSafe 24 ports Gigabit Smart switch
Message 1 of 7
Accepted Solutions
kevin_hong
Apprentice
Re: ACL rules
Hi hacesoft,
Please following the configuration below:
2.VLAN 11 perimt access internet and special address camera _1 / camera_2 , Right ?
Configuration ip acl "VLAN11"
permit destination address 192.168.20.20  ---  permit specail address can access form vlan 11
deny destination subnet 192.168.20.0 0.0.0.255  --- deny 192.168.20.0/24 subnet
deny destination subnet 192.168.30.0 0.0.0.255  --- deny 192.168.30.0/24 subnet
permit any any  ---- permit access internet and other ip address
bind your vlan11 port inbound
3.VLAN 20 permit access all vlans and no permit access internet,
you just can delete 192.168.20.0(vlan 20) static-route on your Route
4.VLAN 30 only permit access internet
permit any any
bind your vlan30 port inbound
Notes:
Please see attachment examples about ip acl
Message 7 of 7
All Replies
kevin_hong
Apprentice
Re: ACL rules
Hi hacesoft,
Welcome to community,
Let's clarify your request one by one.
1. Management switch:  Only special ip address can login and management switch
--- you can set access control, then no other address is accessible
 2.Disable access to special address from VLAN 11 to VLAN 20, Right ?
--- i need more detail information about it. such as  deny vlan 11 ipadd 192.168.11.10 access vlan 20 192.168.20.20.
    Please provide more detailed requirements for acl
Thank you
Message 2 of 7
hacesoft
Tutor
Re: ACL rules
Good evening,
in the attachment I send a picture describing how I want to configure my home network.
Perhaps it is more visual than a verbal description ...
Message 3 of 7
kevin_hong
Apprentice
Re: ACL rules
Hi hacesoft,
Thank you for your feedback.
First,  Let's clarify your needs.
1.Only one pc can access and management your switch(You don't need a configured vlan 40)
--- you can set access-control on your switch
2.VLAN 11 perimt access internet and special address cancea_1 / cancea_2 , Right ?
Are these correct ? Did i miss anything?
Message 4 of 7
hacesoft
Tutor
Re: ACL rules
Good evening,
almost everything is right, but the stimulus difference is that I want the VLAN20 too.
Otherwise you understand it well from the drawing.
Message 5 of 7
hacesoft
Tutor
Re: ACL rules
OK
YES
YES + permit access internet
YES
Message 6 of 7
kevin_hong
Apprentice
Re: ACL rules
Hi hacesoft,
permit any any
Notes:
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2834 views
  • 0 kudos
  • 2 in conversation
Announcements
