Orbi WiFi 7 RBE973
Reply
Can't access GS116Ev2 after switching Broadcast Forwarding to Hardware Mode
pcm0
After following the recommendations from the following KM article:
https://kb.netgear.com/31257/Default-IGMP-settings-may-affect-multicast-streams-on-NETGEAR-Web-Manag...
I was able to solve my multicast stream issues.  Unfortunately, setting broadcast forward method to hardware disabled access to the GS116Ev2 switch even from the web GUI.  I expected the ProSafe utility to not work (as indicated by the warning), but I was also unable to access the switch from the web GUI either and had to factory reset and restore config to get it working again.  Is there something else I need to do?
Note - I tried only disabling IGMP snooping and leaving broadcast forwarding to dynamic, but it didn't solve my original connection issues.  Only by setting broadcast forwarding to hardware did I notice the original issue disappear.
Note, the GS116Ev2 is setup with several VLANs and gets its IP via DHCP.  The firmware is the latest at 2.6.0.24....
Model: GS116Ev2|ProSAFE Plus 16-port Gigabit Switch
Message 1 of 2
Accepted Solutions
pcm0
Re: Can't access GS116Ev2 after switching Broadcast Forwarding to Hardware Mode
After some trial & error, it looks like the switch needs to have a static IP when switching broadcast forwarding to HW mode.  I guess that makes sense so the switch knows when it's being addressed as it's no longer "snooping", but this wasn't documented well...
Message 2 of 2
All Replies
pcm0
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1066 views
  • 0 kudos
  • 1 in conversation
Announcements
