Orbi WiFi 7 RBE973
Reply
Connecting XS7xxT with GS7xxTS with AXC761 DAC
bscaz
Initiate
Hello Netgear community,
We have a 10G XS712T switches and a new 3 x GS752TX stack.
Can we use AXC761 DAC to connect the XS712T with the GS752TX stack ?
If not, any suggestions of other options we could try.
Thanks in advance,
bscaz
Model: GS752TPS(B)|ProSAFE 48-Port Gigabit Stackable Smart Switch with PoE and 4 SFP uplinks, XS712T|ProSAFE 12-port Smart Switch with 10G fiber|EOL
Message 1 of 2
Accepted Solutions
XavierLL
NETGEAR Employee Retired
Re: Connecting XS7xxT with GS7xxTS with AXC761 DAC
HI bscaz,
Welcome to our community!
Yes you can use the AXC761 to to the interconnection , the only think is that please make sure that the GS752TX ports are configured in Ethernet mode and not Stacking mode.  You can check it under the Stacking Menu on the System Tab:
Moreover you can use 2xAXC761 and configure a LAG between the GS752TX and the XS712T so you can have redundant uplinks.
Hope it Helps!
Xavier Lleixa
NETGEAR CBU PLM
Message 2 of 2
All Replies
XavierLL
HI bscaz,
Hope it Helps!
Xavier Lleixa
NETGEAR CBU PLM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3345 views
  • 1 kudo
  • 2 in conversation
Announcements
