- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Device view not working! Java not supported anymore
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I can't re-enable a port on my GS108Tv2 because the Device View tab requires Java and Java applets are not supported by any browser anymore (I'm on a Mac, and Safari, Chrome, and Firefox all no longer support Java applets). What should I do? Is there an updated version of the software that I can use?
Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Jilljoll,
Welcome to the community! 🙂
To disable / re-enable a port on the GS108Tv2, kindly try the steps below:
1. On the web-GUI, go to Switching > Ports > Port Configuration.
2. Check the box next to the port to configure.
3. On the Admin Mode column, select Disable then click Apply.
4. Check again the same box next to the port to configure.
5. On the Admin Mode column, select Enable then click Apply. This will re-enable the port.
Kindly read pages 3-1 to 3-3 of the GS108Tv2 user manual here as reference guide.
Hope it helps.
DaneA
NETGEAR Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Jilljoll,
Hope it helps.
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
