- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Fiber Connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have a GS752TXS w/ 4 10G fiber connections and a GS728TX-100NES w/ 2 10G fiber connections, both using AXM761 modules. On the GS752, port 49 is connected to a NAS, port 50 is connected to a server. When I connect the GS728 to port 51, the link led's will light up, nothing connected to it can see anything from the GS752. Any help will be appreciated.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi KevinB15,
It very helpfull about the provided information.
On GS752TXS Port 51,52 are stack ports. So they can't be used for ethernet connection.
We need to change port 51,52 from stack mode to ethernet mode with following steps.
1.Go to "System /Stacking/Stack Port Configuration"
2.Select port 51/52.
3.Change configured stack mode to Ethernet.
4.Click Apply on the right bottom。
5.Restart the switch.
Hope it helps
Best Regards
Carl
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Fiber Connection
Hi KevinB15,
Welcome to the community!
Can you help to share the following information
Ports status about GS752TXS (port 49,50,51) via "Switching /Ports"
Ports PVID status about GS752TXS and GS728TX via "Switching/Vlan/Advanced/Port pvid configuration "
Regards
Carl
Netgear Employee
- Mark as New
- Bookmark
- Subscribe
- Permalink
Physical Status Link Status
49: 10G full Link Up
50: 10G full Link Up
51: blank Detach
52: blank Detach
current PVID
49: 1
50: 1
51: 0
52: 0
and GS728TX
PVID
27: 1
28: 1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi KevinB15,
Hope it helps
Best Regards
Carl
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, I had already changed it, I didn't do the restart.
Thanks for the help.
