- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS105Ev2 Firmware Update will not go into Bootloader Upgrade mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
I noticed that the device's firmware was still at v1.4.0.5 and the Bootloader was (not surprisingly) v1.4.0.5-VB , and went to the product's Downloads list, saw that v1.6.0.3 was the current firmware version.
So I followed the simple procedure provided
https://kb.netgear.com/000060282/GS105Ev2-Firmware-Version-1-6-0-3
The firmware update was accepted, updated, it rebooted, and once I logged back into the devices, instead of it presenting me with the Bootloader Upgrade page, as described in Step 9:
9. When login to the switch, it will go to Bootloader Upgrade page.
I was back to the normal Switch Information page -- which showed the Firmware version was in fact updated, but the Bootloader was still at v1.4.
I tried again, and no change (Einstein's defintion of insanity?). I looked around and found that there was a Bootloader bundled with the v1.5.0.4 firmware update, so I attempted that "upgradde." The instructions were the same -- Step 9 should have brought me into the Bootloader Upgrade page. But it didn't. So I went back to firmware v1.6.0.3.
Is there a way to force the device to present the Bootloader Upgrade page? Otherwise, I'm stuck.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
You are not seeing the bootloader update page because firmware knows you already have the latest bootloader. Latest bootloader version is 1.4.0.5
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS105Ev2 Firmware Update will not go into Bootloader Upgrade mode
Hi Stev3D,
You may try to go directly in the bootloader page. Please try this http://x.x.x.x/loader_upg.htm (x.x.x.x represents your GS105E’s IP address).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you, JohnCarloV , for the suggestion. I wish it had worked.
I tried the URL you provided (obviously replacing "X.X.X." with the approriate IPv4 address) and after authenticating, I was brought to the normal "Switch Information" page. I postulated that the authentication step is hard-coded to coming to that default page -- so I tried to reach the the "/loader_upg.htm" page again multiple ways, including pasting that URL into a new tab, and simply replacing "login.cgi" text in the address bar with "loader_upg.htm" -- and in every case, I got a completely blank page.
I also tried it using a completely different Web browser (one stripped-down with no add-ons, blocking, etc -- which I use for diagnostics), and the results were identical: A completely blank page.
I have tried software reboots, and power-cycling -- no change.
Do you have any other suggestions?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
May you be able to try updating the firmware using the Prosafe Plus Utility? It seems that it did worked on this thread.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Peter-K2 , thank you. It is embarassing that it was something so trivial. I was unable to find any clar documentation or indication to that effect
