- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS108PE 802.1Q VLAN - PVID not applied to untagged packets on trunk port
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there!
I am using the 802.1q advanced configuration on this switch.
I wonder if the PVID tag is applied to untagged packets coming in on a trunk port.
There is no indication in the manual that this is the case.
My use case is a wireless access point, that sends its management traffic untagged, while sending different WLAN SSID traffic with a 802.1q tag.
So the switch should take the untagged packets and put it on my default VLAN, defined in PVID setting.
Any inputs appreciated
Cheers
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@tagme wrote:I am using the 802.1q advanced configuration on this switch. I wonder if the PVID tag is applied to untagged packets coming in on a trunk port.
That's what the PVID configuration is for.
@tagme wrote:My use case is a wireless access point, that sends its management traffic untagged, while sending different WLAN SSID traffic with a 802.1q tag.
Management VLAN ID: [U]ntagged, same PIVD
WLAN SSID VLAN IT: [T]agged.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
