Orbi WiFi 7 RBE973
GS724TPS Inter-VLAN Routing ?
MadTom_T
Hi
Can anyone advise if this switch support Inter-VLAN Routing.
If it does, how do I set it up.. if not what are my options ?
Thanks
Model: GS724TPS|24-port ProSAFE Gigabit Stacking Smart Switch with PoE|EOL
Message 1 of 2
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: GS724TPS Inter-VLAN Routing ?
Hi @MadTom_T,
The GS724TPS does not support Inter-VLAN Routing.  You will not find the term 'Inter-VLAN Routing' in the GS724TPS data sheet here and also in the GS724TPS user manual here.
If you need a smart switch that supports Inter-VLAN Routing, I recommend you the GC728XP.  For more information about the GC728XP switch, kindly access its data sheet here.
Furthermore, access the link below and select the switch that matches your network requirements:
NETGEAR Switch Selector
DaneA
NETGEAR Community Team
Message 2 of 2
All Replies
DaneA
Hi @MadTom_T,
DaneA
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1104 views
  • 1 kudo
  • 2 in conversation
Announcements
