Orbi WiFi 7 RBE973
Reply
GS724Tv4 Backup config .. Where ?
john510
Follower
Using a Netgear GS724Tv4 .. Is there a way to backup the configuration of the switch after its up and running in the event it ever has to be reconfigures or reset
Message 1 of 4
Accepted Solutions
JohnRo
NETGEAR Employee Retired
Re: GS724Tv4 Backup config .. Where ?
Hello john510,
Welcome to the community!
I see you are looking for a way to backup the configuration of your switch, let me help you out. You can use the Smart Control Center Utility (download here) to upload and download the configuration file for your switch. See image below for reference:
For full instructions, please click this link and go to page 19. Also, you might want to check out the product page for your switch it will help you a lot with troubleshooting and and tips.
I hope this helps you out, if you have more questions we'll be happy to help.
Thanks,
Message 2 of 4
All Replies
JohnRo
Hello john510,
Thanks,
Message 2 of 4
Napsterbater
Apprentice
You can go into the Web Config (via IP address, can't use a DNS name due to a bug) , then goto Maintenance, then Upload, then select HTTP File Upload, then Pick Text Configuration in the drop down, then click apply in the bottom right.
Message 3 of 4
JohnRo
Hello john510,
@Napsterbater's advice is also a great alternative.
Thanks,
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 27435 views
  • 5 kudos
  • 3 in conversation
Announcements
