- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS752TP v1 to v2 - Same backup file?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My GS752TP-100NAS (v1?) just stopped working and it seems Netgear is sending me a GS752TP-200NAS (v2?) as a replacement.
On the support page you can select v1/v2 and they have different firmware releases so I'm assuming the firmware is not interchangeable which is fine.
But my backup file with my settings for my switch is from my v1 - will it work on the v2 switch without issue after import?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
FYI for anyone wondering; I just manually reconfigured my new v2 switch. I did not use the v1 config or try to import it as the new webGUI looks different than the old one.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS752TP v1 to v2 - Same backup file?
I just read this in the GS752TPv2 release notes, does this mean I cannot use a v1 backup config file?
Limitations:
- Configuration migration from older devices GS728TP/ GS728TPP/ GS752TP to new devices GS28TPv2/ GS728TPPv2/ GS752TPv2 is NOT supported.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi IOTdiot,
Welcome to our community! 🙂
Thank you for sharing your solution! We look forward to hearing more from you!
JohnCarloV
NETGEAR Community Team
