Orbi WiFi 7 RBE973
Is a GS908E a Managed Switch?
PeteCalxx
The box says "......Smart Managed Plus Switch"  but on the,
NETGEAR-Product-Registration-FAQ
it is listed under Unmanaged switch (87).
And what does a Management VLAN mean?
Model: GS908E|8-port Gigabit Ethernet Smart Managed Plus Switch with Cable Management
Message 1 of 3
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: Is a GS908E a Managed Switch?
@PeteCalxx,
Welcome to the community! 🙂
Thanks you this report. The GS908E belongs to the Smart Managed Plus Switch models.  I have already sent a request to correct this article.
The purpose of a Management VLAN is to prevent unauthorized users from accessing the configuration of the switch.  You can have at least one port as member of a Management VLAN.
Be informed that the GS908E does not support Management VLAN since it is a Smart Managed Plus Switch.  Smart Managed Plus Switch Models gives user the flexibility to configure certain static layer 2 settings in order to improve network efficiency and performance.  The configurable features are Port Mirroring, VLAN, QoS, Rate Limit, and Broadcast Storm Filtering.
If ever you want to implement a Management VLAN to your network, I suggest you either of the following switch models below.  Click the links to learn more:
Smart Managed Pro Switches
Insight Managed Smart Cloud Switches
Fully Managed Switches
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
Message 2 of 3
All Replies
DaneA
@PeteCalxx,
DaneA
Message 2 of 3
PeteCalxx
Thank you.
I have a lot to learn.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1272 views
  • 0 kudos
  • 2 in conversation
Announcements
