- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Link Aggregation (LAG) question
- Mark as New
- Bookmark
- Subscribe
- Permalink
I never setup LAG before on switch ports, so just to make sure, when I setup LAG, it have to be done on two switches right? For example from switch A and B.
If I only setup LAG on switch A what happens? My understanding is that LAG is used for redudency, load sharing, and higher bandwidth.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@tantony wrote:..., when I setup LAG, it have to be done on two switches right? For example from switch A and B.
Correct.
@tantony wrote:If I only setup LAG on switch A what happens? My understanding is that LAG is used for redundancy, load sharing, and higher bandwidth.
If you connect two different systems, if you connect a switch using both (non-configured) ports, to this LAG - I'll promise a nightmare and mess on your LAN.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Correct.
