Antworten
MS510txpp - VLAN configuration different then on the GS724tv3?
Hello!
I am upgrading my network from 1gb to 10gb / Multigigabit. I have a cisco switch as my core, and am connecting netgear switches in a hub an spoke arrangement. I have GS724tv3´s running since about 7 years without problems with my VLAN setup, but I haven´t been able to get the new MS510TX running in this setup.
VLANS:
VLAN10 - Clients
VLAN11 - Servers
VLAN12 - Firewall
I have a configured VLAN Trunk, and I Tagged all those vlans on the MS510´s uplink port, and Untagged on the ports where I wanted to use it. I have left the vlan1 active, as netgear switches have seemed to need this. (Atleast the GS724v3 config had it like that..)
But I run into a strange problem. The management interface is in vlan 1 (Which I had deactivated in my network) and if I changed it to vlan 10 or 11 - I needed a factory reset to regain access to it. that was the first part I found very annoying. So I left it be for the configuration.
Then I configured all the ports and started connecting devices to it. The only network that worked, was - at first glance - the vlan 10. Clients got a ip adress and where able to connect to services running across on the cisco switch. I was not able to get the VLAN 11 and 12 (and all the rest, but just to keep it simple I´ll stick with those 3) running at all.
After hours of searching, I have come to the conclusion that the only VLAN that really works, is the VLAN1 - If I remove the PVID1 from any port, that port stops working at all (Remembert, the "first" vlan - vlan10 clients worked in the initial tests!) if I added the VLAN1 atleast the client port started working again. Very strange. Maybe this modell needs a working vlan1 for whatever reason? I added a vlan1 to my cisco, setup a whole new network segment for this "Netgear management" 192.168.0.0/24 (just in case.. the default ip the MS510 falls back on, is 192.168.0.239) with DHCP, dns and every thing. So when I now start a factory reset fresh config, with only VLAN1 active I was awaiting ips from the network 192.168.0.0 - but instead I STILL got the VLAN10 ip´s.
If I connect the GS724v3 again, it all works as expected with out me changing anything. All VLANs are useable (about 20 in total) and the ports in different vlans actually use different IP areas (No assmeteric vlan crap!!)
Has anybody some pointers how to get a MS510tx running with vlans in combination with a cisco switch?
I have a case open (40614725) but am hoping somebody might have an answer already!
Thanks alot for your help
Nachricht 1 von 5
Slas
NETGEAR Employee Retired
Re: MS510txpp - VLAN configuration different then on the GS724tv3?
Hallo @MemyselfundNetz
Es ist generell möglich, das Management VLAN auf ein beliebiges VLAN zwischen 1 und 4093 zu ändern.
Wenn der Switch nach dem Ändern des Management-VLANs nicht mehr erreichbar ist, überprüfe, ob der PC immer noch mit VLAN 1 Port verbunden ist. Verbinde den PC mit einem Port, der Mitglied des neuen Management VLANs ist und teste die Verbindung zum Switch.
Hast du die VLANs auf dem MS510TX vor der Verbindung mit dem Cisco Switch getestet?
Hast Du den VLAN-Setup sowohl am Cisco als auch am Netgear Switch erneut überprüft?
Überprüfe, ob die Switches mit den richtigen Ports verbunden sind.
Sehe dir den folgenden Artikel an und lass mich wissen, ob es für deine Einrichtung geeignet ist.
How to configure VLANs on a ProSAFE S3300 Stackable Smart Switch with shared internet access
Hier ein Beispiel für VLAN-Trunking zwischen zwei Netgear-Switches.
How do I setup a VLAN trunk link between two NETGEAR switches?
Grüße
Slas
NETGEAR Community Team
Nachricht 2 von 5
Servus!
ja ich habs dann doch hin bekommen. die config ist zwar nen bischen gewöhnungs bedürftig - aber ich hab folgendes gemacht:
auf den ACCESS ports, hab ich das VLAN 1, + das vlan was ich eigentlich verwenden wollte Untagged drauf, + pvid vom gewünschten VLAN
auf den TRUNK ports, hab ich NUR die vlan´s die ich nutzen wollte als Tagged, und VLAN1 entfernt. PVID aufs "native" gelegt, und prompt gings. Sobald ich von den Accessport das VLAN1 weg nehme, krieg ich kein keine packete mehr durch. ganz komisch, aber solangs so tut. ich passte nachher mal screenshots.
Nachricht 3 von 5
Slas
ich freue mich, dass die Verbindung funktioniert.
Soweit ist es richtig, wenn du an beiden Enden (Trunk Ports) das entsprechende untagged native VLAN konfiguriert hast. Native VLAN-IDs müssen laut Cisco an beiden Enden des Trunks übereinstimmen.
Für eine weitere Überprüfung würde ich die Tech Support Datei von Netgear Switch und die Konfiguration von Cisco benötigen.
Grüße
Slas
Nachricht 4 von 5
Am Port g1 hängt ein Netgear switch - der braucht das vlan tag 1 zusätzlich zu den Untagged ports
auf den LAG Ports hängen eine NAS und ein Cisco WLC - die brauchen auch das vlan 1 damit das vlan10 funktioniert
Am port XMG9 hängt der Cisco switch als uplink. der braucht vlan 1 als vlan member aber NICHT als VLAN Tag. Die PVID hat da komischer weise nicht wirklich was gebracht - so wegen native vlan etc. Die PVID ist aber bei den access (untagged ports) wohl wichtig.
 Die Cisco config für den uplink port sieht wie folgt aus:
da ist das native vlan 10 eingetragen, aber wenn ich die pvid auf 10 änder beim uplink, wars das mit der Verbindung. Sehr verwirrend, aber so läuft es erstmal, wenn auch es für mich null sinn macht 😄
Nachricht 5 von 5
Autoren, für die die meisten Kudos vergeben wurden
Diskussionsstatistiken
  • 4 Antworten
  • 2642 Aufrufe
  • 1 Kudo
  • 2 in Unterhaltung
