Orbi WiFi 7 RBE973
Reply
New 10-Port PoE+ Switch with Cloud Management Option GS110TPP
BretD
Admin
GS110TPP is a 10-Port Gigabit PoE+ Ethernet Smart Managed Pro Switch with 2 non-PoE copper ports and optional remote Cloud Management.
The new NETGEAR GS110TPP provides higher PoE budget and integrates the industry leading NETGEAR FlexPoE technology, which allows users to increase the PoE budget by simply buying a new power supply, effectively futureproofing small business networks and budgets.
NETGEAR now expands Cloud Management capabilities to select models within its Smart Managed Pro switch line, including this new model GS110TPP. The GS110TPP adds full 8 port PoE+ support for deployment of modern PoE devices with 2 additional Gigabit copper ports. Each PoE+ port can provide up to 30 watts with a rich total PoE power budget of 120W
Visit the GS110TPP Landing Page for more info.
Read the GS110TPP Press Release
What is FlexPoE?
Flex PoE is an upgradeable PoE budget with an interchangeable power adapter and built-in power adapter selection in the management GUI.
Message 1 of 6
Accepted Solutions
BretD
Admin
Re: New 10-Port PoE+ Switch with Cloud Management Option GS110TPP
Let us know in the comments what you plan to power with this new PoE+ Switch!
Message 2 of 6
All Replies
BretD
Admin
Message 2 of 6
schumaku
Guru
No plans yet, but missing a GS110TPP-like Smart Managed Pro model with two SFP+ (yes 10G) or with two 10GBase-T (or MultiGig) uplink ports, similar to the Smart Managed Plus GS110EMX, for some bandwidth hungry PoE+ applications where a LAG of two GbE ports can't cover the bandwidth requirements. One example might be the feed of mutiple GS105PE or GS108T for example.
Message 3 of 6
SimonCanine
Guide
Have you fixed the problem that disallows local login if connected to the network?
Message 4 of 6
schumaku
Guru
Lack of a User Manual, the Installation Guide does still show the disliked Netgear Account login method only.
Message 5 of 6
schumaku
Guru
@YeZ please....
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 11221 views
  • 1 kudo
  • 3 in conversation
Announcements
