Orbi WiFi 7 RBE973
SFP+ Connection between XS716T and XR700 - Which Caable?
KlausKUN
Hi *,
which cable do I need for an SFP+ connection between XS716T and XR700.
Greets
Klaus
Model: XS716T|16-Port 10-Gigabit Copper Smart Managed Pro Switch with 2 Copper/SFP+ Combo Ports
Message 1 of 3
Accepted Solutions
KlausKUN
Re: SFP+ Connection between XS716T and XR700 - Which Caable?
Thanks you.  7m - DAC is ordered.
Greets Klaus
Message 3 of 3
All Replies
schumaku
Guru
What is the distance between these two devices?
On a short distance (1...3...5...7...10 meters), you can consider SFP+ DAC (10G-DAC) cables, like SFP DAC - Direct Attach cables for 10 Gigabit connections available from Netgear as well as second source (use a price search engine).
On longer distances, you need a pair of SFP+ fiber modules with the appropriate and matching preassembled fiber patch cable, for keeping it simple look for Multimode fiber cables and modules which are fine for up to some hundred meters. On even longer distances, you look into single mode fiber cables and modules.
Message 2 of 3
KlausKUN
Greets Klaus
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1293 views
  • 0 kudos
  • 2 in conversation
Announcements
