- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SFP+ RJ45
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't know if this is the right forum, but I wanted to buy a Synology DS2015xs NAS with two SFP+ Ports.
I found the Netgear ProSAFE AGM734 1x 1000Base-T Modul. I did't worked until now with SFP/SFP+ I inly use Netgear Switches with RJ45 cables. Can I use this modul with a non - Netgear - product like this NAS?
(a SFP+ Cable is no option, because I will ise this NAS as a dedicated external backup, so I had to plug and unplug the cable two times a week)
Thank you!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Picmention,
As far as I know, the AGM734 is compatible with the SFP+ interfaces of XSM7224S as well as with the SFP interfaces of GSM7328FS. About the compatibility with the Synology DS2015xs NAS, it may or may not work.
Kindly check this link I found online and it might help. Also, its best that you ask assistance from Synology about your concern.
DaneA
NETGEAR Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Picmention,
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: SFP+ RJ45
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: SFP+ RJ45
Hello,
in the end I decided to buy a Synology DS1817+ which has a 8x PCIe Port with 4x Lanes. This one is has the Intel x540-T2 on its compatibility List and we tested it now also with the Intel x540-T1. It works great with our 10 GbE Switches from Netgear over RJ45 cable. Thank you for your Support!
