- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Switch registered twice
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem of deleting an accidentel double registration does NOT seem to be solved (GS724Tv4 two times registered in my account from 2016).
Receiving no feedback from my registration procedure, I tried it a second time. This time I did get a feedback, but, checking my 'registered products', I find that my switch is listed twice. This leads to problems when starting up and activating a licence key.
.. Therefore again the question: how do i remove the dublicate entry?
Best regards
LAN-Turtle |
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just got a feedback from the NETGEAR Support Team that your concern is now fixed. Kindly check it. 🙂
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
NETGEAR Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Switch registered twice
Hi @LAN-Turtle,
Welcome to the community! 🙂
I have already inquired your concern to the NETGEAR Support Team. I will post an update here once I got a feedback.
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cheers,
DaneA
