- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Switchs compliant 802.3ad network (incuding LACP)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I would like to change our network to be compatible with Qnap NAS setting aggregation port which asks 802.3ad protocol.
I actually have the following switch material (behind a ISP router):
1 x GS116E
2 x GS108
4 x GS105
I need to upgrade with 802.3ad compliant material (incuding LACP).
Which material can you suggest to me?
Thanks for your help.
Best regards,
NC
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Switchs compliant 802.3ad network (incuding LACP)
Thanks.
I will check for smart switchs.
Best regards.
NC
- Mark as New
- Bookmark
- Subscribe
- Permalink
I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Switchs compliant 802.3ad network (including LACP)
Hi,
Accepted solution.
Thanks.
NC
