- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Time configuration on GS 724T V3
- Mark as New
- Bookmark
- Subscribe
- Permalink
I try to setup the SNTP Global Configuration the following way:
1 in Time Configuration set clock source to SNTP
2 In SNTP server configuration :
Server type :DNS
Adress: time-f.netgear.com
Port: 123
Priority: 1
Version: 4
and enter Add
3 in DNS Server configuration
Status: Enable
DNS server 192.168.1.1
and enter Add
Back to Tme:
Nottingchanged
Date still at 01/01/1970
Time 00:35:08
What do I do wrong?
Thanks in advance for a replay
Jan
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I suggest you to update the firmware of your GS724Tv3 switch from v5.4.2.18 to v5.4.2.27. Be sure to perform a factory reset on the GS724Tv3 then reconfigure it from scratch. Try again to setup the SNTP Global Configuration and check the result.
You may download the latest firmware v5.4.2.27 here.
DaneA
NETGEAR Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Time configuration on GS 724T V3
Hi Marum,
Welcome to the community! 🙂
Kindly answer the questions below:
a. Is the SNTP configuration working before?
b. What is the current firmware version of the GS724Tv3?
Kindly try the steps below:
1. On the web-GUI of the GS724Tv3, go to System > Management > Time > SNTP Server Configuration.
2. On the Server Type column, select IPv4.
3. On the Address field, enter the LAN IP Address of your default gateway (router).
4. Leave the Port, Priority and the Version fields on defaults.
5. Click Add.
Note: You may need to reboot the GS724Tv3 for the settings to apply.
Let us know the results.
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hallo, DanaA,
First of all thanks for the fast replay.
The suggestion of the IP adress did not solve the problem.
Boot Version: B5.1.1.1
Software version: 5.4.2.18.
The unit is brand new strait from the box.
The only thing changed is the Software version as i hoped this would solve the problem.
Marum.
- Mark as New
- Bookmark
- Subscribe
- Permalink
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
DaneA,
Updating as suggested did the trick.
Thanks,
Marum.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the update. I'm glad to know that updating the firmware of the GS724Tv3 switch resolved the problem. 🙂
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
