Orbi WiFi 7 RBE973
Reply
Using command line to control internet access on each device port
bjmango
I am looking for a network device. It should allow me to use command line (telnet) to control the internet access per each swither port.
Which model network device could fit my needs? Will GS108Tv2 work for me?  Thanks.
Model: GS108Tv2|ProSAFE 8-port Gigabit Smart Switch
Message 1 of 2
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: Using command line to control internet access on each device port
Hi @bjmango,
Welcome to the community! Smiley Happy
The GS108Tv2 does not support command line interface (CLI) commands.  It supports ACL (Access Control List)  wherein you can allow or deny access such as HTTP or FTP.  Kindly access the article below:
What are Access Control Lists (ACLs) and how do they work with my managed switch?
Since you want to use command line interface (CLI) commands, I suggest you check the NETGEAR Fully Managed Switch models on the link below. The NETGEAR Fully Managed Switch models also support ACL.
NETGEAR Fully Managed Switches
DaneA
NETGEAR Community Team
Message 2 of 2
All Replies
DaneA
Hi @bjmango,
DaneA
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1918 views
  • 1 kudo
  • 2 in conversation
Announcements
