Orbi WiFi 7 RBE973
Reply
VLAN routing & Routing to Internet Router on S3300 [S3300-52X (GS752TX)]Switch
zeelx470
Tutor
Hi guys,
Hopefully someone can help me with this as I have been banging my head on this one for a while. I have an S3300-52X (GS752TX) that I am having issues with. I have been able to create VLANs and managed to get interVLAN routing working. Where I am getting undone is getting the routing setup right so I can route traffic to out internet router.
I hope the example below clarifys what I mean:
I have various VLANS (we'll use to for the example):
VLAN 10 - 10.26.10.0/24 (Gateway: 10.26.10.254)
VLAN 20 - 10.26.10.0/24 (Gateway: 10.26.10.254)
I have a internet router at address 10.26.50.1
Created default route with next hop being the router address. I have also tried to setup a VLAN for the dot 50 VLAN because I got a message setting up Default Route saying it would not work until a VLAN with interface in that range was setup or somthing to that effect.
I have looked at some guides and the manual and I believe the guides offer more info than the manual. I have also looked a solutions to other people problems that were similar but not the same in an effort to see if I can engineer a solution with that guidance.
Also note that I tried putting the management interface in a seperate subnet to prevent any conflicts with routing interfaces. Not sure what to try anymore. This is the first time I have used Netgear Smart Switches.
Any guidance you guys can offer will be appreciated.
Cheers,
Zac
Message 1 of 4
Accepted Solutions
zeelx470
Tutor
Re: VLAN routing & Routing to Internet Router on S3300 [S3300-52X (GS752TX)]Switch
Hi guys, just wanted to report that I had found the solution here.
Message 3 of 4
All Replies
zeelx470
Tutor
I forgor to mention that my router is not capable of doing VLANs so on the switch port connected to the router I added that to the VLANs as an Untagged member.
Message 2 of 4
zeelx470
Tutor
Message 3 of 4
JohnC_V
NETGEAR Moderator
Hi zeelx470,
Welcome to our community! 🙂
Thank you for sharing the solution! The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1946 views
  • 1 kudo
  • 2 in conversation
Announcements
