Reply
Admin
Compact and Plus Switches with PoE+ GS305EP GS305EPP GS308EP GS308EPP
Introducing NETGEAR Gigabit Ethernet PoE+ Plus Switches, the best valued switches for small businesses and for those working remotely with plug-and-play connectivity. Offered as an alternative to Unmanaged switches when additional configuration and control is needed.GS308EPP_Diagram_10Nov20.png
Ranging from 4 to 8 PoE+ ports, and a total PoE budget from 62W to 123W of power, the new NETGEAR Gigabit PoE+ Plus Switch family can power your bandwidth-hungry devices, like surveillance cameras, smart door locks, wireless access points, VoIP phones, and much more. They are silent designs that are fanless with passive heat dissipation. They offer compact designs that fit on a desktop or just about anywhere else they are needed.smart-interface-skinny.png
Check out the new Smart Managed Plus GUI in action.
Simply configure your network with a new and improved user-friendly NETGEAR Plus Web GUI. These switches also offer business-friendly features like network separation (VLAN), traffic priority (QoS), enabling and disabling PoE power per port, PoE prioritization, PoE power limit per port and more. Finally, these switches come with a robust 5-year warranty. Your investment will be safe for yeast to come.
Finally, an easy to manage switch, with fundamental network features at an affordable cost for SMBs.
Learn more about our latest GS300 Gigabit Plus PoE+ Switch offerings:
5-Port PoE+ Plus Switch With 63W Total including Plus Management Web GUI Model GS305EP
5-Port PoE+ Plus Switch With 120W Total including Plus Management Web GUI Model GS305EPP
8-Port PoE+ Plus Switch With 62W Total including Plus Management Web GUI Model GS308EP
8-Port PoE+ Plus Switch With 123W Total including Plus Management Web GUI Model GS308EPP
Read our recent blog to learn 10 Reasons Why customers love Plus switches.
Read the press release on these new Managed Plus Switches.
The NETGEAR Managed Plus Gigabit series includes the following models: GS105E, GS105PE, GS108E, GS108PE, GS116E, GS305E, GS308E, JGS516E, JGS516PE, JGS524PE, GS750E, and the latest models, GS305EP, GS305EPP, GS308EP, and GS308EPP
Please click KUDOS or REPLY If you found this helpful.
Message 1 of 5
Initiate
Re: Compact and Plus Switches with PoE+ GS305EP GS305EPP GS308EP GS308EPP
What is the power consumption of these models (without PoE devices attached)?
Message 2 of 5
Guru
User Manual Gigabit Ethernet Smart Managed Plus Switches Models • GS305EP • GS305EPP • GS308EP • GS3... p.91 / p.92 Power Consumptions
Model GS305EP and GS308EP technical specifications
The following table shows the technical specifications for models GS305EP and GS308EP.
Power consumption
GS305EP: 4.9W (no PoE), 74.7W (with PoE max)
GS308EP: 6.0W (no PoE), 74.4W (with PoE max)
Model GS305EPP and GS308EPP technical specifications
The following table shows the technical specifications for model GS305EPP and GS308EPP.
Power consumption
GS305EPP: 4.5W (no PoE), 137.8W (with PoE max)
GS308EPP: 5.9W (no PoE), 141.4W (with PoE max)
Hard to understand why this essential information does not make it to the Data Sheet | GS305EP, GS305EPP, GS308EP, GS308EPP - it' not in the D-GS305EP/GS305EPP/GS308EP/GS308EPP-16Oct20 edition at least. @YeZ please forward....
Message 3 of 5
Initiate
Many thanks for your quick reply! Somehow I missed the user manual. 😊
Message 4 of 5
Guru
Yes, the UM was my last resort, too ;-)
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 936 views
  • 3 kudos
  • 3 in conversation
Announcements
