Orbi WiFi 7 RBE973
Reply
GS-108Tv2 Firmware upgrade hanging at 22% or less completed
Dantech-1
Tutor
I have tried previously to firmware upgrade my switch unsuccessfully.  Tonight I was determined to give it another go.  I did the following:
- Used the recommended SCC (Smart Control Centre) software version 1.1.3.2
- Discovered the switch IP which was in my subnet, IP address 192.168.2.42
- Used my PC  with IP address 192.168.2.16 and clicked on Maintenance/Firmware and Download Firmware.
- To see the progress you have to click on the Task tab!
-  The firmware started to download but hung at 22% and after a while I had to quit.  Fortunately no damage done.
I did this a few times but it refused to download.
Then I thought "my computer is plugged into an HP switch and the Netgear is plugged into the same switch which are on my domain"
I decided to try just connecting the laptop directly to the Netgear switch and see if it worked.
Success - it upgraded first time perfectly.  The lesson learnt was don't firmware upgrade through another switch - do it directly.
I hope this helps someone else.
Model: GS108Tv2|ProSafe 8 ports gigabit smart switch
Message 1 of 3
Accepted Solutions
Dantech-1
Tutor
Re: GS-108Tv2 Firmware upgrade hanging at 22% or less completed
This worked - to firmware upgrade you should connect a LAN cable directly to the switch, do not plug in anything else and keep it off the network.  Install the SCC software on the PC connected to the switch.  Also ensure both the switch and PC are in the same subnet or the switch warns you and gives you chance to quit.
Problem solved - I first tried this months ago but gave up.
Message 2 of 3
All Replies
Dantech-1
Tutor
Message 2 of 3
JohnRo
NETGEAR Employee Retired
Hello Dantech-1,
Thank you for sharing the solution. We appreciate your help!
Thanks,
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4354 views
  • 1 kudo
  • 2 in conversation
Announcements
