Reply
Highlighted
Apprentice
GS724t v4 6.3.1.16 BUG with VLAN Config Page
On the Port PVID Configuration Page
When trying to change VLAN Member and VLAN Tag from 12-14 to 12,14, VLAN Member was changing correctly but VLAN Tag was not, it would stay 12-14.
Note I had the same issue on another port, I was changing from 12-14 in both to 13 in both, again VLAN Tag stayed as 12-14.
The only way to fix it was I had to use None in VLAN Tag, save it then go back and put 12,14 and 13 respectivly.
Model: GS724Tv4|ProSAFE 24-port Gigabit Smart Switch
Message 1 of 4
Highlighted
NETGEAR Moderator
Re: GS724t v4 6.3.1.16 BUG with VLAN Config Page
Hi Napsterbater,
Thanks for sharing this.  Hope that other community members who encountered the same experience on their GS724Tv4 would post here as well.
Also, we could not yet declare that this is a bug on firmware v6.3.1.16 unless the engineering team has confirmed it.  It would be best to open an online case with NETGEAR Support then kindly report about what you have encountered on your GS724Tv4.
DaneA
NETGEAR Community Team
Message 2 of 4
Highlighted
NETGEAR Moderator
@Napsterbater,
I just want to follow-up on this.  Were you able to open an online case with NETGEAR Support and tell about what you have encountered on your GS724Tv4?  If yes, let us know about the progress of it.
DaneA
Message 3 of 4
Highlighted
Apprentice
Not dealing with it.. I reported it here, not a big enough problem for me to deal with them. It Netgear wants to fix it so be it, if not ohwell. They still never fixed that last problem I worked with them on and was jsut a waste of time.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3313 views
  • 0 kudos
  • 2 in conversation
Announcements
