Reply
Highlighted
JGS516PE not saving 802.1q tagging information on power fail
I have no problems setting up the switch with vlans based on the 802.1Q with trunking between 8 port netgear managed switches. However if there is a power fail the 8 port switches all come back with the proper advanced 802.1Q tagging for the vlans. The JGS516PE however looses all the tagging information. The vlan is there, but all the ports are set back to vlan 1 and untagged. This has occured several times, and the rest of the configuration seems to stay through the power outage just the 802.1Q tagging is lost. What have I missed?
Message 1 of 4
Highlighted
Guru
Re: JGS516PE not saving 802.1q tagging information on power fail
Duplicate, close or merge please.
Message 2 of 4
Highlighted
I can find no postings regarding saving of configuration of advanced 802.1Q.  There is no issue getting it to work just all the ports loose the tagging config on power fail. This requires manual entry again every time. I have proved this 5 times. If it is a duplicate that has been solved please provide the link.
Message 3 of 4
Highlighted
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 347 views
  • 0 kudos
  • 2 in conversation
Announcements
