- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Lost of three Port for some reason at times
- Mark as New
- Bookmark
- Subscribe
- Permalink
New installed switch to replaced old version, have set up static IP address to switch and all other network devices by way or cisco rvs4000 router, switch has a static IP address, submask & gateway setup, label port config and enable ports. Problem is, after some time the first three ports seem to disable thenselves, that is lights not lit as well. I need to remove intranet cable from port 1 and connect to port 4 to address the switch and enable ports again, why and thanks
Hap
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Current firmware? https://www.netgear.com/support/product/GS108Tv2.aspx Update, factory reset, and re-test.
Check the switch logs ... Management -> Logs ... there might be indications what makes the ports shut down.
Note: This is a community forum, not a Netgear support channel.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Lost of three Port for some reason at times
seems no one has an answer, tho many have viewed, not many users have a smart switch in use. would have hope someone from netgear would have responded, maybe being a holiday will need to wait a few days. the switch for now seems to be working, but there is always a bug in the works
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, thought this was a Netgear Support Source, will review the firmware update before downloading, have review any pass issues- no results of my problem- devices has been working correctly for some time now since I started from the beginning once more yesterday- hoping this device will continue to work as needed.
Hap
