Reply
Highlighted
Follower
NOOB VLAN Question
Total VLAN Noob question here.
My router has a special VLAN for GuestWifi on port 10.
Now i got an accesspoint without VLAN-tagging possibility.
This accesspoint is connected to the GS724T switch.
How can i configure the switch so it "converts" the VLAN10 on port22 in a manner that when i connect the accesspoint to this port, all the clients receive an VLAN Ipaddress in stead of a normal IP...?
Model: GS724T|24-port Gigabit Smart Switch
Message 1 of 3
Highlighted
NETGEAR Expert
Re: NOOB VLAN Question
Hi pauley,
Create VLAN 10
Go to VLAN membership
       Select VLAN 10 under VLAN ID.
       Marked "U" as Untag for port 22 and "T" as Tag the uplink port under Unit 1 where you getting the VLAN 10 DHCP pool like VLAN aware router or windows server.
         Click Apply
Go to Switching > VLAN > Advanced > Port PVID Configuration
          Change the PVID to VLAN 10 for port 22.
          Click Apply
Message 2 of 3
Highlighted
Guru
Excellent step-by-step explanation by @Nodism1125
A dedicated port might indicate that this is not a tagged VLAN, so the switch port connecting to the router can run untagged (U).
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 350 views
  • 0 kudos
  • 3 in conversation
Announcements
