Reply
New 8-Port Multi-Gig Smart Switches MS510TXUP & MS510TXM #NETGEARCES2021
BretD
Admin
Introducing the NETGEAR 8-Port Multi-Gigabit/10G Ethernet Smart Switch MS510TXM, and the 8-Port Ultra60 PoE++ version MS510TXUP. These switches are ideally designed to connect your NETGEAR WiFi 6 Access Points such as the WAX610 or the WAX218 at 2.5G speeds for full performance. Multi-Gig Switches Press Release.
Featuring Flexible Multi-Gig Connection and Advanced PoE
The NETGEAR MS510TXM 8-Port Multi-Gigabit/10G Smart Switch offers 4 ports 1G/2.5G and 4 ports multi-gig/10G with 2 dedicated 10 Gigabit fiber ports for WiFi 6 AP connectivity, IP surveillance and mobility. Additionally, the NETGEAR MS510TXUP comes with the same Ethernet connectivity options, but also includes Ultra60 PoE++ support (295W total PoE budget) available on all 8 copper ports. The Industry-standard 802.3bt Ultra60 PoE++ can provide up to 60W to advanced WiFi Access Points, PTZ cameras, LED lighting, high-power speakers, AV-over-IP and IoT devices. Go beyond 1G on standard Cat-5e (1G/2.5G/5G/10G) - learn more about Multi-Gigabit switching technology.
Cloud or Local Switch Management Options
Both switches can be managed remotely by NETGEAR Insight and includes 1-year of Insight Premium or Pro subscription. By default, the included local web GUI NETGEAR Smart platform provides intuitive access to all switch functions.
Whisper Quiet Switches
The thermal design of both switches are ideal for noise sensitive environments. Even at full PoE load the MS510TXUP maintains a maximum of 33 dB at 25°C (77°F) ambient. With the MS510TXM able to maintain 25 dB at 25°C (77°F) ambient.
Product Summary
MS510TXUP 8-port | Insight | PoE++ | Multi-Gig/10G | 10G Fiber Uplinks Switch
Multi-gigabit copper PoE++ (up to 60w) ports: 4x (1G/2.5G).
Multi-gigabit/10 Gigabit copper PoE++ (up to 60w) ports: 4x (1G/2.5G/5G/10G).
SFP+ uplink ports: 2x.
Total PoE Power budget: 295 Watts. Each port supports PoE, PoE+ and PoE++.
Smart Managed or Insight Managed.
MS510TXM 8-port | Insight | Multi-Gig/10G | 10G Fiber Uplinks Switch
Multi-gigabit copper ports: 4x (1G/2.5G).
Multi-gigabit 10 Gigabit copper ports: 4x (1G/2.5G/5G/10G).
No PoE included.
Click for more CES2021 Community Coverage
Or Visit our CES2021 for Business Page
Please click KUDOS or REPLY If you found this helpful.
Message 1 of 1
Discussion stats
  • 0 replies
  • 2726 views
  • 4 kudos
  • 1 in conversation
Announcements
