Reply
Highlighted
Follower
XS724EM - Traffic forwarding from a single 10G SFP+ port to multiple RJ-45 copper port
Can I do the following on XS724EM?
Traffic is entered in the XS724EM switch through one of the two 10G SFP+ ports having multiple streams of different VLAN ID. Let's say, 10 streams with VLAN ID 1 to 10, each stream occupying 10% of 10G bandwidth i.e 1G each. Can I forward this different VLAN stream to different Copper ports (e.g stream of VLAN ID 1 from 10G SFP+ port to Cu port 1, stream of VLAN ID 2 to Cu port 2, stream of VLAN ID 3 to Cu port 3, and so on)?
Model: XS724EM|24 Port 10-Gigabit/Multi-Gigabit Ethernet Smart Managed Plus Switch with 2 SFP+ Ports
Message 1 of 2
Highlighted
Guru
Re: XS724EM - Traffic forwarding from a single 10G SFP+ port to multiple RJ-45 copper port
Yes of course, that's a normal trunk config where frames from multiple VLAN enter the switch. Only one VLAN can be untagged, the PVID defines the VLAN ID will be assigned to.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 68 views
  • 0 kudos
  • 2 in conversation
Announcements
