× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Can I Backup Stora to Stora
psteel
Tutor
Hi
I have 2 storas on the same network. Is it possible to backup 1 stora device to the other using desktop mirror. I have tried setting up the folder paths and the destination stora copies the folders over from the source, but the folders are empty and the log comes up with messages such as:
02:01 copyFolderToServer failed for: PHOTO-HOME-MUSI\MyLibrary\Music. Backed Up
02:01 Backing up \\PHOTO-HOME-MUSI\MyLibrary\MusicVideos. Backed Up
02:01 building file list ...
02:01 sent 21 bytes  received 20 bytes  82.00 bytes/sec
02:01 total size is 0  speedup is 0.00
02:01 copyFolderToServer failed for: PHOTO-HOME-MUSI\MyLibrary\MusicVideos. Backed Up
Desktop Mirror completed on 2015-09-06 02:01
Message 1 of 4
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Can I Backup Stora to Stora
Hi @psteel,
Backing up the files from one Stora to another through the Desktop Mirror feature will not work due to authentication issues. However, it can be done by manually transferring the files.
Dexter
Community Team
Message 2 of 4
All Replies
DexterJB
NETGEAR Moderator
Hi @psteel,
Dexter
Community Team
Message 2 of 4
psteel
Tutor
Thanks for your timely reply. It has saved me much time and frustration
Message 3 of 4
Southkil
I use free file sync for the PC. It works very well.
Message 4 of 4
Discussion stats
  • 3 replies
  • 5872 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
