× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Cant register after reflash
mb1978
Can't register my Stora MS2000 after reflash. Trying my Product Key and previous Stora Name (maybe I'm pointing it out wrong)
Gets me error. Any help?
Message 1 of 3
Gitsov
Virtuoso
Re: Cant register after reflash
Are you sure that you are using exact same unit name?
Not sure how but when I got for a first time at home my second hand unit somehow I managed to reset it's registration (it was registered already and I did not know previous details). Only what I can remeber was that I tried to reset it to factory defaults and at some point I managed to do it, but it was already registered with active registration. After firmware recovery there is no registration data at all, so probably you should on painful route - write to Netgear support to reset registration which is bound to your key.
Message 2 of 3
mb1978
Thanks, the technical support helped me. device works
Message 3 of 3
Discussion stats
  • 2 replies
  • 897 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
