× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Error Code 8058
adammc
Error Code 8058
Hello,
I am trying to copy files from my Stora to my downloads folder on my macbook Pro.
I keep getting:
The operation can’t be completed because an unexpected error occurred (error code -8058).
I can browse to the store / family library ok in finder.
If I try to paste an item to store, I get this:
The operation can’t be completed because one or more required items can’t be found.
(Error code -43)
What can I do?
Message 1 of 4
Southkil
Re: Error Code 8058
hi,
i'm not a mac user but looking around on the net i found this solution.
[QUOTE]But I did find something that might be related. Someone else had a problem deleting a file and getting the same error code. They trashed their finder preferences (~/Library/Preferences/com.apple.finder.plist) and it fixed things. Unfortunately Apple hides your library folder now so you need to:
    Maybe this will help.
Message 2 of 4
SMRHANS
Novice
Re: Error Code 8058
Well this is one of the common and annoying error. I too faced this error. Had a lot of trouble and finally got a working solution through this article.
http://www.techanges.com/fix-error-code-8058-on-mac/
This really helped me a lot. Hope it works for you too. Thanks!!! 😄
Message 3 of 4
Bhupesh_7
Re: Error Code 8058
It is quite easy to fix this error by simply deleting com.apple.finder.plist.
For detailed information you can click here : Fix Error Code 8058 on MAC
Message 4 of 4
Discussion stats
  • 3 replies
  • 20706 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
