- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Force fscheck ubifs
- Mark as New
- Bookmark
- Subscribe
- Permalink
Force fscheck ubifs
Hello.
I have MS2000 - Stora. And I thought I have an trouble with httpd but there is an rootfs trouble
[root@stora:usr]# /etc/init.d/httpd start Starting httpd: /usr/sbin/httpd: error while loading shared libraries: libaprutil-1.so.0: cannot open shared object file: Invalid argument [FAILED] [root@stora:usr]# ldd /usr/sbin/httpd libm.so.6 => /lib/libm.so.6 (0x40025000) libpcre.so.0 => /lib/libpcre.so.0 (0x400cd000) libselinux.so.1 => /lib/libselinux.so.1 (0x400ef000) libaprutil-1.so.0 => not found libcrypt.so.1 => /lib/libcrypt.so.1 (0x4010c000) libdb-4.3.so => /lib/libdb-4.3.so (0x40145000) libexpat.so.0 => /lib/libexpat.so.0 (0x40227000) libapr-1.so.0 => /usr/lib/libapr-1.so.0 (0x4024c000) libpthread.so.0 => /lib/libpthread.so.0 (0x40277000) libdl.so.2 => /lib/libdl.so.2 (0x40294000) libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x4029f000) libc.so.6 => /lib/libc.so.6 (0x402b2000) /lib/ld-linux.so.3 (0x40000000) libsepol.so.1 => /lib/libsepol.so.1 (0x403e3000) libuuid.so.1 => /lib/libuuid.so.1 (0x4042d000) [root@stora:usr]# ls -la /usr/lib/libaprutil-1.so.0 lrwxrwxrwx 1 root root 21 Oct 2 2009 /usr/lib/libaprutil-1.so.0 -> libaprutil-1.so.0.2.7 [root@stora:usr]# ls -la /usr/lib/libaprutil-1.so.0.2.7 ls: /usr/lib/libaprutil-1.so.0.2.7: Invalid argument [root@stora:usr]# ls -la /usr/lib ls: reading directory /usr/lib: Invalid argument total 0 [root@stora:usr]# mount | grep ubi0:rootfs ubi0:rootfs on / type ubifs (rw)
How can I force fsck ubifs? How should I do it?
I have USB with debian and I can boot from USB. Please any advice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Force fscheck ubifs
Templorary woraroud:
I have backup of root and I extract it to /opt/root
mv /usr/lib /usr/lib1 (cause can't delete)
ln -s /opt/root/usr/lib /usr/lib
It works but i still have errors on the root.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you have complete backup of rootfs (/dev/mtd3) just flash it with nandwrire or ubiformat. These tools will check bad blocks in flash, mark it as unusable and flash the rest of file(s) on good blocks. Contact me in PM if you need more help with this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You will need to do flash_eraseall /dev/mt2 then either to untar tar.gz archive if you have that kind of backup, if it is plain dd image you should write it with nandwrite -p /dev/mtd2 <IMAGE_FILE>, if it is .ubi file - ubiformat is correct tool. Let me know on PM if you need more help. In all cases dd does not play well with mtd devices and does not care that flash is having bad blocks. Don't use dd.
