- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Impossibile hard reset Stora MS2000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tentato almeno 5/6 volte con recovery (famosi 15 secondi) ma senza alcun risultato positivo. Ad ogni tentativo sempre lo stesso comportamento (vedi video).
Modem Tim fibra Technicolor AGVTF_5.3.
Video --> Stora MS2000
Any idea?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ciao @donaz prova adesso a fare il ripristino, a molta gente ha ricominciato a funzionare dato che www.mystora.com è tornato online
Hi @kohdee, it looks like NETGEAR kept the promise and they're bringing back the service. mystora.com is online but there are still issues in remote access, at least the minimum part (obtaining FW after a reflash) is working which I guess it is good for all those who had issues with Stora...
remote access is still not working.
ciao,
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Impossibile hard reset Stora MS2000
The problem is being quenched support Store. Now you Stora useless as my
- Mark as New
- Bookmark
- Subscribe
- Permalink
Non riesci a resettare lo stora perché ha bisogno del suo server per completare il reset. Prova a seguire questa discussione:
https://community.netgear.com/t5/Stora-Legacy/mystora-com-NOT-ACCESSIBLE/td-p/1274638/page/4
Ciao!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ciao mcrs969,
grazie per la risposta. Speriamo che Netgear trovi una soluzione quanto prima. Era 1 anno circa che non richiedeva l'hard reset.... scegliere un momento meno infelice no ehhhh?
Grazie ancora ✌
- Mark as New
- Bookmark
- Subscribe
- Permalink
MyStora e tornata indietro. Puoi confermare che la tua Stora può riconnettersi ai server Stora?
- Mark as New
- Bookmark
- Subscribe
- Permalink
ciao,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting me know. I think I know what the root cause is to that. Give me some time today to see if I can get that working again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I reflesh stora and now cant acsses.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ciao mcrs969 and others,
grazie per le risposte e confermo che il flash è andato a buon fine. Sembra però da quello che leggo, che il server non è ancora del tutto stabile... netgear troverà sicuramente la soluzione al problema quanto prima.
Thank's everyone, and ciao ! 😎😎✌
- Mark as New
- Bookmark
- Subscribe
- Permalink
Impossible is right..,
I can confirm that I can access (a)stora from the web, tested from a local connection AND a 4G-LTE mobile. The certificate is still a little flaky, but I can still bypass that error using the "GO ADVANCED" links..,
However, I still have one BRICKED STORA that only gets to blinking blue power LED if I try a HARD RESET, which I have tried dozens of times, being really careful with the timing. Apparently the unit is NOT getting a DHCP IP assignment, and never goes to the orange LED stage of the reset.
Any suggestions to recover this unit?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rif.: Impossibile hard reset Stora MS2000
Hi
I need to recover my stora, because I lost user e and password.
So, based on what I'm reading here, my stora is simple become no more than an ornament?
