- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
MS2000 not hard reseting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: MS2000 not hard reseting
Hello,
I've sent you message. However update server is experiencing problems with mysql service and activation will fail on step 2 or 3. I am on it at the moment, but first will need to revive my home pc which is having problems either with PSU or Mainboard. I will post here in the forums when I have results.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, @Gitsov
I also have a problem with restoring my Stora. It was working for me for almost 6 years. But today I decided to reflash it because of power supply fail. And I cannot finish restoring procedure. I tried few times but every time I got mistake :
Your Stora has encountered an error.
Error message: at /var/www/admin/update.pm line 346
Please, can you help me?
Thx in advance!
Lev
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I will make post here when I have stable working setup for that. Just check that thread for news.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello!
Today I had phone call with Netgear Hotline, and they informed me that they do not have plans to continue running authorization servers for Stora. They are shut down and will not work in future.
So every owner of Stora potentially has a brick :(.
I hope @Gitsov will find some solution. Nobody else will help us.
Lev
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am in the middle of modification of recovery. Probably in next 2-3 days there will be some news.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry it will take a while. My secondary unit died yesterday and I will need to take another one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you please share that solution with me as well.
Thank you in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
PM sent. Please note that activation will FAIL unless update server is available. There is a pending change of firmware, but for that I need to get replacement motherboard for my second unit...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Betreff: MS2000 not hard reseting
I have the same problem too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I have sent you PM with instructions for reflashning. Please note that activation in case of successfull firmware recovery will FAIL. It's not a problem of recovery itself, but with Netgear's update server. Probably in next 3-4 weeks, when I get replacement board for my secondary unit, I will release required change in firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, I'll wait. Without activation, Stora is useless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thx.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Check your PMs. Please note that online registration/activation will fail, because of broken update server. There is a forum topic for that , check it for solution, until I get replacement board for my testing unit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can find the mentioned forum post over here
https://community.netgear.com/t5/Stora-Legacy/Stora-Error-Message-on-Setup/m-p/1573911
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Gitsov!
Please help the recovery instruction.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@And1_11: I've sent you instructions how to recover firmware. Please note that registration/activation will FAIL, because update server is broken and unit is checking for updates on stage 2 or 3 during activation. Possible options:
A: https://community.netgear.com/t5/Stora-Legacy/Stora-Error-Message-on-Setup/m-p/1573623#M9413
B: Wait for arrival of spare motherboard for my testing unit and then I will do script for fixing firmware and/or fixed firmware. ETA is something like 2 weeks from now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Gitsov,
Please could you send me your recovery script?
Thanks
Matt
- Mark as New
- Bookmark
- Subscribe
- Permalink
@elofty: Is it very urgent?
I am in the middle of modifying firmware to fix update troubles during initial setup... Maybe in next 5-6 days I will need to release modified firmware with last update pre-appllied and disabled update checks. If it is urgent you will need to fix manually update scipts to activate unit and they (probably) will be restored to it's original state when you apply update later....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great thanks. The solution with the modification of setup_update.pm helped. I passed the initial registration. Stora is now working.
I didn't need to update the firmware, because updated to the alternative firmware earlier.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No Worries, Happy to wait 🙂
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This fix helped me! I had some troubles with configuring VM Ethernet ( if you have Win 10 I recommend VMBox 5 ver), but at the end I found solution ( newer ver. of VMBox) and I managed reflash Stora and it work! Now I plan to prepare backup stick to be on the safe side.
Thank you Gitsov! Great job!
