× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
MS2000 not hard reseting
WALEE
Re: MS2000 not hard reseting
Hi, @Gitsov
I also have a problem with restoring my Stora. i bought it 2nd hand and its stuck at
Your Stora has encountered an error.
Help System
Error message: Page 3 of the reset wizard does not exist.
can i get the fix?
Message 201 of 259
gtrave
Hi,
I have problems with your vm that doesn't run correctly on my pc.
Could you please send me your new one to make a try ?
Thanks by advance
Polly
Message 202 of 259
LS00
Message 203 of 259
Gitsov
Virtuoso
@gtrave: I've sent you PM. If you have troubles with VirtualBox try to use VmWare workstation player or VirtualBox 4.x
Check if VT-X/AMD-V instructions are supported by both CPU and BIOS and they are enabled in BIOS. PM me with exact error which you got.
Message 204 of 259
bersim01
HI,
i tried to hard reset my Stora but I can't start the recovery mode. The blue LED dont stop blinking after 15sec of reset (HDD1 LED is orange)
Help please!
Message 205 of 259
Gitsov
Virtuoso
Check your PMs. I've sent you instructions.
Message 206 of 259
jhonjey
Hi at all
I too have the same problem with my Stora...
Can I have the fix and clear istruction (I'm not a computer expert) on how to resolve the problem?
Thanks a lot
Giovanni Staibano
Italy
Message 207 of 259
bersim01
Message 208 of 259
Gitsov
Virtuoso
@jhonjey: I've sent you PM with instructions. Please check PDF file and follow instructions carefully.
I know that it does not look easy on a first look, but in reality it's easier than it looks. Make sure that you have a copy of registration details (unit name and product key), before flashing firmware, as it resets unit to factory defaults.
Message 209 of 259
jakratchet
Hi Can i please have that instruction please? thanks
Message 210 of 259
jakratchet
Thanks in advance gitsov!
Message 211 of 259
Gitsov
Virtuoso
You have PM.
Message 212 of 259
jakratchet
works perfectly, easy process too. thanks for the great work!
Message 213 of 259
jhonjey
And then NetGear made the miracle... yesterday I tried again and this time the setup procedure was fine!!!!
Anyway I have ordered a QNap... and so on!
Thanks to all, particularly to mr Gitsov!!!
GS
Italy
Message 214 of 259
Gitsov
Virtuoso
Don't forget to backup your registration data - next time registration server might suffer such bad fate and then game will be (almost) over.
Message 215 of 259
Twyrdy
Hey there,
I have 2 Storas here that had to be reflashed. It seems, that the recovery mode on both worked fine and on both i get the registration wizard now, but i can't complete registration, neither with the original registered name, nor with any other. Netgear support says registration wion't be possible anymore, but send me the link to this Thread to find help.
Does your solution help here too? I'd like to use these 2 Storas unless i can get a bigger/newer NAS.
Thank you very much.
Greetings
Message 216 of 259
userlink
Hi
I also have the blue led problem. Could you please help me, mr. Gitsov?
Message 217 of 259
thibfighter
Hello there !
Seems that I have the same issue with my stora : after trying to hard reset, all LEDs blink together rapidly (power LED blinking blue and HDD LEDs blinking green) but never stop.
@Gitsov do you think your solution might work ? In this case could you PM it please ? Would be of great help !
Regards and thanks in advance !
Message 218 of 259
Gitsov
Virtuoso
@thibfighter , @userlink - Please check your PMs.
Message 219 of 259
stefansportivo
@Gitsov could you please send me the instruction for how to get my Stora to work again?
Thanks in advance,
Message 220 of 259
Gitsov
Virtuoso
Done. Check your PMs
Message 221 of 259
thibfighter
Big thank to @Gitsov whose method worked indeed !
Message 222 of 259
Dandy444
Hello
Can you please send me a instruction please? thanks
All of lights blinking without stop
Message 223 of 259
Gitsov
Virtuoso
@Dandy444: I've sent you message. Sorry for a delay.
Message 224 of 259
gem1112
I have same issue! Can you PM me please?
Message 225 of 259
Announcements
Orbi WiFi 7
