× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
MS2000
johnhb46
Follower
MS2000
OK, this doesn't seem to be the right place for my question but this is the only place I could manage to get to.
When I login to mystora I get a message stating that stora wants Adobe Flash player installed. I have down this several times, but mystora still wants AFP. I tried using MS Edge, Google Chrome etc but still no join. I need ti access the hard drive in my Stora unit to retrieve urgently needed files. Hope someone cam help me or direct me ti the correct section of this forum.
Model: MS2000|Media Server|EOL
Message 1 of 2
Guru
Re: MS2000
never used this device so I'm just going off research. 🙂 I know many of the browsers are disabling flash. Even if you install it, a lot of times you have to go into settings to force it to work or allow certain sites. depending on the browser you use, just google "enable flash with ******.
Did you try the desktop application?
https://www.netgear.com/support/product/MS2000.aspx
Message 2 of 2
Discussion stats
  • 1 reply
  • 916 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
