- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
STORA MS2000
- Mark as New
- Bookmark
- Subscribe
- Permalink
STORA MS2000
I can see my STORA unit using windows explorer and am able to login to it using the admin username and password. I can see the 3 standard folders: MyComputers, FamilyLibrary and MyLibrary. When I click on any of these folders it comes up with a network error stating that it cannot access that folder and to check the name etc...
If I login using mystora, once again I can get logged in and can see various bits of information about it using the preferences option (although it strangely only shows 1 drive when the lights on the front of the unit are green indicating that both drives are ok), but if I try to access the Media Library I get a message that says "The server resource requested was not found".
Any suggestions ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: STORA MS2000
If you are using Windows 10, you might need to enable the Windows SMB 1.0 client. Go into "turn windows features on or off" - you should find it there.
