- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Stora MS 2110 is it now just a brick?
I have a Stora MS 2110.
I am trying to set it up again after having to rebuild my MAC and network.
I cannot access mystora.com amd cannot register the device.
Is it now just a brick or is there anyway I can set it up just to use either standalone or through my local network?
Thanks for any advice..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Stora MS 2110 is it now just a brick?
Welcome to the Community!
You should be able to access the GUI locally using the IP address of the Stora. Have you tried using the resource CD on setting up your Stora? if you need to set it up again, it will need internet connection. However, Stora mystora.com has been taken down last April 01, 2020.
HTH
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I understand it is dead and buried.
I need to reconfigure my Stora to be able to access it, and to access it I need to use MyStora.com.
But I am under the impression MyStora.com is now dead and will not be coming back online.
So either need to find another way of configuring my Stora, or.........?
Seems a waste, as it is fully functional and I am sure there must be some way of reflashing it with some generic software like FreeNAS to get it to work standalone. I have no interest of the MyStora application anyway, just want to use it as backup on my own Wifi network for local backup and storage.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks Marc.
So does that mean there is no way of setting it up again without MyStora.com?
Can I reflash it anyway using something generic such as FreeNAS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The Stora service has ended last April, it has been out of service since then.
If you will just set it up the first time or setting it up again, there is no way anymroe to do that since it needs to connect to Stora service which is our of service already.
Reflashing it might not be possible with NETGEAR Support but unofficial way there might be, just not sure how or what to use.
HTH
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi,
what you are saying is ridiculous: my device works perfectly and because it needs an hard reset it becomes a brick only because Netgear decides to close the website.
There would be legal action!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thank you for your helpful advice Luigi.
What I am saying is not ridiculious or legal action, it is a simple question asking for help as i have been unable to get My Stora up and running again once the My Stora site was closed down.
Any assistance appreciated.
Unhelpful comments not so.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi
there are some tutorials on the net to install a debian on this black glamour brick, just search for "netgear stora debian".
Things you need
- Netgear Stora :-)
- A TTL serial port, and wires to connect it.
- An USB stick. Preferably with +10MB/s write speed, and +8GB capacity.
- A PC to serve as a TFTP server, and to connect to the Stora via the TTL serial port.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi,
Like many of you on this thread I've been looking for a way of accessing my 'bricked' stora.
Thinking ouside the box I remembered having a Stora App on an old iPad1. Given that Flash is the problem with access from a PC I figured that as Apple doesn't use Flash(?) it might still work?
So I dug out my old iPad, charged the battery, booted it up and....Hey presto! The app still works. I now have limited access to my Stora using my old iPad. I can see all the content but can't do anything much with it. Haven't figured out how to move stuff to my new chosen storage platform which is a Synology NAS but at least I can see the files and open them.
I appreciate that this isn't a universal solution and it won't be of use to everyone... but it mght be the beginings of an idea for a workaround?
Please keep me posted if you can push this approach any further than I have managed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
EVEN BETTER NEWS!!
I have an ancient iMac running Snow Leopard - which has old Flash Player installed and uses Safari as its standard browser.
I dusted it off, fired it up and connected to my Lan - where my Stora is attached.
I tried to connect to the Stora locally using Safari and the Stora's ip.
Once agin - SUCCESS! I have access to the full gui front end to the Stora.
I'm going to transfer the files I need from the Stora to my Synology NAS either by copying them to a USB stick or by enabling FTP on the Stora. Watch this space.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
CONFIRMED.
Transfer of files from the Stora using USB and FTP (via Filezilla) works successfully.
Hope this helps. I know other Linux based options exist but for anyone like me who knows diddly-squat about Linux this has been a much easier workaround.
Regards to all...stay safe
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi,
Got the same problem when Flash was cleaned from my computer. Then it was not possible to use the Stora web interface in any browser in Win10.
But I have an old Acer laptop with WinXP still working. Used the browser Maxthon, still using the Flash, to log into the Stora, it works just fine to configure settings.
Happy that my Stora did not became a brick, been working fine since nov-2011.
Two 1 TB WD HD never any issues with disks running 24/7.
@gatepark wrote:CONFIRMED.
