× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Stora Software Update & HD Problem
pdizz
Follower
Hi
Bought a Stora MS2110 and 2 new 1TB HD's (Seagate Barracuda's ST1000DM003) When the Stora boot both HD lights turn green and the orange. When I access the Stora Application it says:-
Hard drive not configured and RAID action required.
No Hard drives are configured. You need to configure your RAID an the preferences.
After clicking OK another box pops up saying:-
Software Update Available.
A software update is available.
Would you like to apply now.
YES NO
On clicking YES it show:-
Software Update Failed.
OK
Then the Preferences box appeares and I click RAID. Tis show both HD's as:-
Status: Inactive
Disks Seagate ST1000DM003-1ch1 931.51GB Unused
Format Rebuild
If I click Format the warning pops up and then the Application say:-
The disk(s) are now formatting, as a result the device will be rebooted. This may take a few minutes, please wait until your device has rebooted before logging back in.
OK
I click OK and wait, wait, wait........ There does not seem to be any drive activity (lights stay solid orange) and nothing seems to happened, even after 1 hour.
Any suggestions on what the problem could be?
Thanks
PD
Message 1 of 4
Southkil
Re: Stora Software Update & HD Problem
Hi, Follow the sticky to reflash your stora. All should be well after that. :)
Message 2 of 4
schoeny
Did this work?
Message 3 of 4
DexterJB
NETGEAR Moderator
Hi @schoeny,
Have you tried performing the re-flash? If not, you may refer to the link below for the recommendation:
https://community.netgear.com/t5/Stora-Legacy/Re-flash-your-NetGear-Stora/m-p/264219#M441
Dexter
Community Team
Message 4 of 4
Discussion stats
  • 3 replies
  • 7211 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
