- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Stora drive compatibility list
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Stora drive compatibility list
http://www.makovec.net/upgrading-netgear-stora-nas-drives-without-copying-data/
as for the RAID, i think you select RAID 1
- Mark as New
- Bookmark
- Subscribe
- Permalink
With this info I went from a single 1tb to a single 2tb and although lengthy it worked well. I did for peace of mind take the 1 tb drive out and cloned it first as I wasn't happy with some of the posts of people saying they had lost data when inserting drives. My theory was that if they both have the same data then I should be ok.
Once cloned I put the 1 tb back in its original slot (1) then the new 2tb in slot 2, at this point the 2 tb was still at 1tb capacity. From this point I just followed the guide, failed the second drive via root access etc, rebuilt then grew the volume etc and viola I now have a single 2tb with no data loss at all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Southkil wrote: you might want to look here for a possible way of upgrading without copying the files back and forth.
Thanks but 'll take the long hard road 😛 I´m opying everything from the original 1tb to an external hdd, then pop the 2 tb in and copy back, very exciting as.friday entertainment.:D
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
http://forum1.netgear.com/showthread.php?t=72007&page=3
- Mark as New
- Bookmark
- Subscribe
- Permalink
It supports the WD20EZRX?
- Mark as New
- Bookmark
- Subscribe
- Permalink
jorge33 wrote: I have already asked someone before .... but no one has answered ....
Its a good question that no one seems to answer. All the other drives on the list are discontinued.
So for bumps sake is the WD20EZRZ compatible with this NAS??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Based the listed compatiable hard drives listed below, I purchased (2) 2TB
HUA722020ALA330 hard drives. They arrived and I placed them in the Stora, did a hard reset of Stora, and then proceed though the setup wizard. When I get to the 'detect HD' step in the wizard, I am told there are no HD installed in the unit. Can you tell me what I am doing wrong? I confirmed the model number on the HD. Do I need to initialize or format the drives someway before inserting into Stora?
Argiejr
- Mark as New
- Bookmark
- Subscribe
- Permalink
http://www.ebuyer.com/390983-wd-red-1tb-3-5-sata-6gb-s-64mb-hard-drive-wd10efrx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Argiejr wrote: Rsinj and/or Anybody who can help,
Argiejr
Argie...sometimes the drives come pre-formatted.
Try connecting directly to your desktop and remove all partitions, then try again in the Stora.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ST3750640AS (7200.10) works.
ST3750630AS (7200.11) does not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
And thanks a lot for all of your contributions :
I've just finished upgrading my NetGear Stora MS2110-100PES
from a 2x 1TB drives RAID1 to a 2x 2TB RAID1 with a pair
of 2TB Western Digital WD20EFRX NasWare 3.0 disks.
Here are the references of the procedures used and parts bought :
1) Using a computer running Windows 8.1, and Basilisk (supporting Flash)
as a Web browser, I first checked if I manage to connect via ssh to my NAS
with Putty, using one of the ''Administrators'' accounts, according to this tutorial :
''Easy Root Access''
https://github.com/Dees7/openstora/blob/master/pages/Easy_Root_Access.md
The login format was as announced :
USERNAME_hipserv2_netgear_XXXX-XXXX-XXXX-XXXX
Web-Browser-Login-Account_hipserv2_netgear_Labelled-Product-Key
2) Using the tutorial :
''Upgrading NetGear Stora NAS drives Without Copying Data''
https://dan.makovec.net/useful-stuff/upgrading-netgear-stora-nas-drives-without-copying-data
I also checked if I actually manage to get ''root'', using some of the non-modifying
commands in this tutorial.
3) I then bought 3x 2TB Western Digital WD20EFRX NasWare 3.0
hard drives (+1 as a spare) on the eBay store of the seller called ''deoptimus''
based in Germany :
WD RED 2TB WD20EFRX NASware 3.0 NX HA500 5400U/min 64MB SATA III 3.5''
https://www.ebay.fr/itm/403737305766
4) Once the hard drives received, I externally set one of the new hard drives
in a similar position to the 1st hard drive I will have to replace in the NAS,
so as to start a 24 hours warm-up cycle.
I then replaced the 1st hard drive (on the right into the NAS), according to the tutorial :
I then carefully followed this same tutorial to upgrade the NAS, taking profit
of the 1st RAID1 rebuilding delay to start an over-the-night warm-up cycle
for the 2nd hard drive, set in a similar position to the 2nd hard drive (on the left) I will
have to replace.
Lead to success, these tutorials allowed me to double the capacity of my NAS :
Thanks again !
- « Previous
- Next »
