× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Stora stopped working?
PETTEW
Follower
My Stora worsk for about 10 min and then stops. And I can´t log in again. Have to stop it and start it over .
Can I put my disks in a Netgear Redy and copy my disks from there?
Message 1 of 2
DexterJB
NETGEAR Moderator
Re: Stora stopped working?
Hi @PETTEW,
1. Have you tried resetting the Stora? If this an option for you, you may refer to the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/20608/~/how-to-reset-the-stora-to-factory-defaults
2. Are you referring to the ReadyNAS? If yes, then no since it uses a different file format and will require you to format the drives.
3. I recommend connecting the drives to a Linux computer for you to recover the files and back them up before doing anything.
Dexter
Community Team
Message 2 of 2
Discussion stats
  • 1 reply
  • 3218 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
