- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
USB Backup doubts and questions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
since some day I bought premium pack and started using USB Backup feature.
I have some questions on it:
1- of course drive where I'm doing my backup is attached to the stora device through usb port on the stora itself. I have anyway the feeling that when backup job is running my local network incredibly slows down. I think it doesn't make sense (files should be trasferred locally from the device to the port, without really using the LAN). Someone else noticed this? is it possible?
2- on DAY 1 I did backup of around 200 GB and it tooks more than one day.
On DAY 2 same backup job was running and, even if there were no changes on the folders, it took anyway around 8 hours. Someone else noticed this? Why backup procedure isn't recongizing that nothing changed? Is there a way to activate this kind of incremental backup?
3- why if I detach usb drive, when I plug in back I'm loosing configuration of list of folders under backup procedure? I feel this is working in the way you should leave backup drive always connected. Someone else noticed this?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: USB Backup doubts and questions
80phoenix wrote: Hi,
Thank you
no hints from anyone on this over?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see that Stora has two options of USB backup:
Synchronized backup and
Archive
I tried synchronized backup and yes it's unbelievable slow, every day, I am not sure if this is an incremental backup or not. I guess it can not be a full backup if the 2 backup took less time than the first backup.
I tried also archive (i use it for photos) but whenever i add a new subfolder with photos to the stora, they don't seem to be backed up.
I will try again with the synchronized backup. My idea is to connect the usb disk to the stora whenever i add photos to the stora and remove it again after the a few days when the backup should be ready.
I am not sure if i always need to go to preferences and chose eject disk, or if it's enough that the usb disk is not at use when i remove it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The solution is indeed designed so that the disk is a permanent backup. Managing files on the backup disk from another system may confuse the backup.
Cheers,
Roby!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried archive and it's like you say yes. I added a subfolder after i did the archive, and it was not added to the archive later, as expected.
I have another question, wold be nice if anybody has a clue. After i copied about 300 GB of photos to the Stora, both disks (raid1) have been running continuously for a week, also when i don't do USB backup. Anybody has a clue what it is doing and if it's normal? Before i did this, the disks were not active when not used, and they used to shut down after 15 minutes of inactivity.
They are still running and reading and/or writing.
