Reply
pjg_pigeon
Tutor
Re: Unable to reflash stora
Hello Gitsov, Please, can you help me with my Stora? With Kind Regards Pete
Message 176 of 323
Gitsov
Virtuoso
Hello,
check your PMs. I've sent you instructions.
Happy STORA MS2120 Owner.
>Buy me a coffee if you liked my work: https://paypal.me/Gitsov/2
Message 177 of 323
Skystriker
Hi! I also have the same Problem like anyone else   ...
Trying to fix my stora since 1 week and did not find and solution yet Smiley Sad
Please help Gitsov!
Many thanks in advance! Smiley Happy
Message 178 of 323
Gitsov
Virtuoso
Hi,
You have PM with instructions.
Message 179 of 323
mantif21
Hi
I have the same problem for weeks now....
Can you help?
Many thanks
Message 180 of 323
Gitsov
Virtuoso
Hello,
PM with instructions was sent few moments ago. Check your PMs.
Message 181 of 323
mantif21
I managed to recover my Stora.
Message 182 of 323
Gitsov
Virtuoso
Glad to see that solution worked for you :-)
Message 183 of 323
Cooldjmc
Hi Gitsov, please can you share solution also with me.
Message 184 of 323
Gitsov
Virtuoso
Hello,
Check your PMs - I have sent you instructions.
Message 185 of 323
pjg_pigeon
Tutor
Hello,
I managed to recover my stora.
Thank you very much
Message 186 of 323
Gitsov
Virtuoso
Thank you very much for donation. I am happy to see that it helped for you.
Message 187 of 323
gausley
I managed to recover my Stora!
Many Thanks!
Message 188 of 323
Cooldjmc
Thank you for solution, managed to recover the unit.
Message 189 of 323
mtlstphn
I am also looking to reflash but will this work with Verbatim Mediashare as well?
Thank you!
Message 190 of 323
Gitsov
Virtuoso
Hello,
I am not sure that it will help for Verbatim. Even if hardware is similar, boards can be different and this recovery will brick it even more. Can you drop me a PM? I can try to help if I can.
Message 191 of 323
sullacorda
Hi,
I have a stora version and I started having permissions problems. I tryed to reflash but it doesn't work. Can you send me your solution?
thanks a lot for your support
Michele
Message 192 of 323
Gitsov
Virtuoso
Done. Check your PMs.
Message 193 of 323
whsanch
Gitsov, if you could be so kind as to share the solution with me as well, it would be much appreciated!
Thanks.
Message 194 of 323
Gitsov
Virtuoso
Check your PMs. I have sent you instructions few minutes ago.
Message 195 of 323
whsanch
Thank you, Gitsov!
My Stora is back up and running like the day I first set it up!
Message 196 of 323
Sao18
‎2018-03-04
Hi Gitsov
I'm having difficulties with resetting my mp2110 Stora similar to the others here. Please can you help me too? Any help you could offer would be very much appreciated...
Kind regards from Steve
Sao18
Message 197 of 323
Gitsov
Virtuoso
Done. Usually either PM or message here is enough to catch your call Smiley Happy
No need of additional pressure...
Message 198 of 323
pele61
Thanks for all your help, I've managed to recover my Stora, much appreciated!
Message 199 of 323
Led71
Hello Gitsov,
Same problem here: I need access to the Stora, but there's no way to get into the box. Would appreciate it much if you could sent me your solution.
Grtz. D
Message 200 of 323
Top Contributors
Announcements
