- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
factory default MS2000
- Mark as New
- Bookmark
- Subscribe
- Permalink
I made a factory default at my NAS, after that i can not access it anymore.
I can ping the NAS but i can´t setup my NAS.
I don´t know what to do, can anyone help me?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: factory default RND 2110
What happens when you enter https://nas-ip-address/admin in your web browser?
Also, what status is RAIDar showing you? https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
- Mark as New
- Bookmark
- Subscribe
- Permalink
No diffrent if i try "https://192.168.0.161/admin".
Will test the other later, just wonder which RAIDar version i should try ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Version 6.3 is fine for this.
The only issue with version 6.3 and legacy NAS is if you want to get into flexraid. That requires RAIDar 4.3.8
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now i test with RAIDar 6.3 and not find the drive.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you still ping it?
What happens if you power down the NAS, remove the drives (label by slot), and then power it up again? What should happen is that RAIDar should find the NAS and report a "no disks" status.
Also, what firmware is your NAS running?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: factory default MS2000
Yes i can ping my stora, i also see that it´s not stora 2110 it´s an MS2000.
I take out the disk but no diffent.
I don´t know my firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A Stora is not a ReadyNAS which would explain why the troubleshooting above didn't help. I've moved your thread to the correct board.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does anyone have any ideas that can help me install the Stora MS2000?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What LEDs are lit when HDDs are outside?
Blue "power" LED is blinking or after some period of blinking become steady? Is any HDD LED are blinking despite that HDD drives are out?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Without disk:
Blue blink 5 times then wait little then blink 5 times again and continue like that ...
With disk:
Both disk led steady green.
And i can ping the device ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unit is in bootloop. Usually that 5 blue blinks should occur once and the LED to become steady. Probably unit is bricked, either because you tried by accident to recover firmware (most likely) or because NAND developed bad cell. Check yout PMs - I've sent you instruction for firmware recovery.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I try to make a FW recovery but it seems not work.
Blue light up and hdd blink green/orange ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please read carefully PM and documentation which I've sent you. Follow instructions carefully if you want to recover firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don´t know what i make wrong, i not get instruction from you how to recovery, i try this:
https://community.netgear.com/t5/Stora-Legacy/Re-flash-your-NetGear-Stora/td-p/264219
- Mark as New
- Bookmark
- Subscribe
- Permalink
Check your Private Messages ( mail letter envelope on top right side). I have sent you message. That recovery which you are doing is just stock recovery process which does not work, because server which should serve firmware isn't available anymore (Netgear decided to stop it for some reason). Check PrivateMessage (PM) which I've sent you, read PDF file and follow instructions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If anybody could PM me the recovery PDF that would be great. Really want my Stora back up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Sorry for a delay. I've sent you PM with required files and documentation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi!
I'm also have bricked stora 2000
Can you send me solution for recovery on PM ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same problem for my stora MS2000, could please help me? I can’t load the firmware...
Thank you !
Ben
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
You have PM with instructions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
After a few emails and support calls I've managed to get a win for us all. The recovery site 'should' be back up and running now.
I am still to confirm this but I got an email confirmation last night that the binary download has been fixed for the recovery process:-)
Hopefully this will help the Stora community.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is accessible from my location at the moment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm suffering symptoms which might be related. I have another thread on my own situation specifically but I wonder if the solution you suggest here may be the one I need. My Stora threw a wobbly a week ago and I needed to use the online recovery process. It stalled the first time and after 48hours of churning I powered down (had to unplug) and repeated it. It seemed to take the second time and I have full access to my files both on the local network and by web access. The only problem is that now MiniDlna is not running and I can't get it to start.
I have SSHd onto the Stora via Putty and had a look around. There seems to still be an installation of MiniDlna which I can use for a little diagnostic work, (when I quewry it it tells me there is no server running for example), but I am stumped from there.
I don't know the current state of play with MiniDlna and Netgear. Is this another aspect which we have lost? Or do I just have a corrupt copy which would be sorted out by reinstalling everything with another repair? Is it possible that your procedure could help me too Gitsov?
