Reply
Novice
Netgear WGT624-v3 NAT Settings Question
How do I change NAT Filtering on my Netgear WGT624-v3 router.
Last September I received the following reply, to my post that my SC101 was causing internet disconnects:
Hello Terry,
Log on to your router and go to the WAN Setup.
On the NAT Filtering, select open.
However when I log on to the router I don't see the setting. The
WAN Settings Screen options were:
Connect automatically (checked)
Disable SPI firewall (unchecked)
Default DMZ (Unchecked)
Respond to Ping on Internet (Unchecked)
MTU Size 1500
How do I open NAT Filtering.
My original post was:
When my SC101 is online I lose Internet connectivity for other computers through my home network every few
minutes. When it's offline I can keep an Internet connection all day long. Is there a way to prevent the
Internet Connection drops?
The SC101 is on firmware 4.22.13. My Router is a Netgear WGT624-v3. I connect to the internet through a
Speadstream DSL Modem to ATT DSL. All devices connected to the router remain connected. I can see other
computers and the SC101 on my home network. It's just the internet connections that drop. If multiple devices
are connected to the internet they all drop about the same time. The connections usually come back in a minute
or two, but it's very disruptive since I telecommute and have to re-logon through my company's security.
Re: Netgear WGT624-v3 NAT Settings Question
hello! i have had similar issues since i bought this router. i currently use a text/call service on my ipod and it couldnt connect to the call service. i found online that i needed to change my nat setting to "open". every forum i looked at told me to look under the wan settings but i could not find the nat settings anywhere in the routers menu. i tried upgrading the firmware and once i did that the option to change my nat settings was added to the "wan settings" section in the routers menu. i realize your question is 5 years old but it was one of the first things i read when i started researching my issue today so i figured id help people out who stumble across your question in the future.
firmware upgrade http://downloadcenter.netgear.com/en/Disclaimer.aspx?redirecturl=http://netgeardownload.registria.co...[sku]=wgt624v3&download_url=http://www.downloads.netgear.com/files/GDC/WGT624V3/wgt624v3_2_0_26_1_0_1_na_only.zip
Discussion Stats
  • 1 reply
  • 16517 views
  • 0 kudos
  • 2 in conversation
