Reply
Follower
ReadyShare
This might be a stupid question, but I'm not afraid to ask. I just purchased a Netgear WNDR 3400 Dual Band Router. How does the Readyshare work? I use Mac X and the external hard drive is Hammer 750gig. I connected the USB from hard drive to the router and I do not see the hard drive. Is there something I'm not doing?
Thanks
Novice
Re: ReadyShare
I have found this link ftp://downloads.netgear.com/files/readyshare_flyer_9Jul09.pdf and I hope that it could help you. You need to check if your USB device is on the compatibility list. Click the link http://support.netgear.com/app/answers/detail/a_id/14313/related/1 for the compatibility list.
Re: ReadyShare
First, post future questions regarding your WNDR3400 in the appropriate subforum. Second, as Strider08 advised, if your ext. disk has no propriety drivers or internal firmware for backup/encryption etc. it should work.
Re: ReadyShare
If this is not proper for WNDR 3400 COmpatibility issues, which one is and how do i get to it. These forums are very confusing. Secondly if you can does anyone keep a good new compatibility list as new USB devices are coming out all the time. I can not even find the devices they say are compatible in my local Best Buy store, they have newer models.
Re: ReadyShare
Go to this subforum.
Don't think anyone else keeps a "good new compatibility list"......
Read the first lines of the relevant KB Netgear page and use that as a general advice.
Discussion Stats
  • 4 replies
  • 14570 views
  • 1 kudo
  • 4 in conversation
Top Contributors
User Kudos Count
1
