Reply
Broken NTV200 Remote - Help
My remote for my NTV200 box is broken. I am currently using the iphone app, but it doesn't have a power button. The problem is, if I take my NTV200on vacation, there is no way for me to hook up to a new wireless network without the issued remote working. I can not find an IR code for the NTV200 for a universal remote. I could not find on Netgears site or anywhere an option to just buy a replacement remote.... Anyone have any ideas?
Luminary
Re: Broken NTV200 Remote - Help
if the unit still in warranty contact support at my.netgear.com
also you can use logitech harmony remote which you should able to use it with all your functions
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Thanks!!! Called support and they sent me a new one. Also, I think I'll try to connect my Logitech remote...then I can use that as an alternate if the netgear remote malfunctions again.
Luminary
sounds great... I use Harmony remote and works on just about all devices...
good luck
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 3 replies
  • 11389 views
  • 0 kudos
  • 2 in conversation
